I've written a couple of times and done a lot of things to try to cure this problem. My 1999 merc 75 hp runs great and doesn't cut out at all from 0 to 4200 RPM's. When I give it full throttle and get on it, the motor starts to cut out every 5 to 10 seconds at 5000 to 5100 rpm's. I have also noticed I have a oil/gas (thick) mixture that leaves a heavy residue on the inside of my motor on my intake, and also blows the mixture on the inside of my transom 1 foot inside my boat.
A couple of weeks ago it was only cutting out at WOT every 1 to 2 minutes.
My question is, the boat is from North Dakota, guessing 2000 Feet in elevation. Where I live the elevation is at 4000 to 4500 hundred feet in elevation. Do or can you jet your carbs ?? and any idea why I would have this heavy residue. I've changed my fittings and cant find a leak anywhere.
