Re: Can you tell me what this is?
The box has a receptacle with 3 female pins inside the connection. Not sure what the switch does. I have never had to use it while under way.
I intended to put the radio in the original spot, but the new radio's cover is slightly smaller than the original. I guess if I wanted to mount it in the original spot I would have to first mount a filler plate over the existing hole. I was thinking if I bought new plexiglass for the replacement dash, I could cut a piece off for a cover plate and then bolt the new radio cover to that??
