benathlete
- Joined
- May 26, 2010
- 4
I have an issue with my mercury 40hp 2 stroke 4 cylinder 1992. it cannot rev over 4000rpm, the propelle is good and the carbs too. i just went for an overall check up and the mecanician found that the stator was failing and replaced it!
But it didn't change anything ! still cant'reach more than 4000 rpm,
my engine does'nt go fine in WOT, it seems to go better if i pull back the throtle a bit..
the thing is: on the flyweel; it is written something like :max spark 33? at cranking speed of 300 rpm , witch is 30? at 5500 rpm. so i used my timing lignt and checked the timing..... it cannot reach more than 27? at cranking speed and the advance adjustement screw is pulled back to maximum .
i think my battery is good because i have 12.56 vdc .
Do you think this is due to a trigger problem or switchbox or something else?
please help me!!! i really want that problem to end!!
Thank's Benjamin (sorry for my english)
