cannot remove 1987 OMC Cobra gimbal ring
Status
Not open for further replies.
cagg
Seperated tiller arm from gimbal assembly but cannot seperate the gimbal ring from the gimbal housing. Any tips/special tools?
sea wolf
Re: cannot remove 1987 OMC Cobra gimbal ring
it should come off easily. u did remove the 2 bolts on each side? you'll need a 1/2" hex wrench. what do u mean by tiller arm?
cagg
1/2 Hex bolts are out. I have seperated the tiller arm (stearing arm)from the top of the Gimbal post. This is done inside the top of the gimbal housing. The gimbal ring does not drop.
sea wolf
did u remove the shift cable? what are u trying to accomplish? more details please. i have the same setup. had it off many times.
cagg
I have the shift cable off. I am trying to grease and change the seals on the lower gimbal post in efforts to overcome difficulty when steering.
cagg
Problem resolved. Utilized special tool #0984146. Required considerable pressure. Thanks Mr. Wolf
Status
