ib18
- Joined
- Mar 2, 2013
- 489
Last Friday, I was preparing for my ocean fishing so starting the boat Johnson 90 hp up. I had no trouble starting it up, but had trouble keep it running unless I keep the throttle higher than normal idle speed. So, I opened the motor cover and discovered fuel was dripping out of the front carb intake. I was surprised, so I researched it online and found people saying probably a stuck carb float or worn out fuel float somewhere. Today, I decided to remove the carb from my motor. Bummer, I got stuck because the studs from the engine block were too long. I was not able to remove the nuts without stripping them. So, do I just use a dremmel saw to grind or cut the studs shorter so I can remove the carb? or what? is this normal to you. 1982 Johnson 90hp v4. J90MLCNB is the serial number.
Thanks.
Thanks.
