Have a year 2000 Mercruiser 5.7 carborated with an Alpha 1, generation 2. I had just had the starter rebuilt, changed the plugs, new wires from battery to ground and from battery to starter. Started right up on muffs in my driveway shifted into forward and engine died. Started it back up and I could not shift it into forward or reverse. I can push the neutral button and move the shifter but it will not move without nuetral button engaged, even when the engine is shut off. Any thoughts? Oh, I have never had a problem with this engine before. It has never been in salt water, always is winterized by dealer, has gear lube and waterpump was replaced this year. I have never put muffs on this boat in 8 years until today.
