Re: Canoe outboard and anti-ventilation question
Hi,
I have a removable, "no holes" motor mount that is quite slick for my canoe. It doesn't go right on the stern, but rather attaches to the cross brace just behind the rear seat and portrudes enough on the port side to mount the motor on. I think it would be a PITA to have the motor right on the stern if that is what you are intending. The 2 hp's need to be turned 180 degrees for reverse, and you'd have to reach way back to adjust the throttle... the handle's probably too short too.
What ever mount you make up, remember that the motor mount plate needs some angle on it. If it was 90 degrees to the surface of the water, your motor would end up trimmed up when mounted.
As for how it will handle... remember that the motor pushes from the prop. Imagine what it would be like if you mounted a 2x4 sticking down into the water (like where the prop would be). Now if someone grabbed the bottom of the 2x4 and either pushed or pulled it to the side. The effect is that it acts like a lever that will want to make the canoe rotate down it's long axis (capsize). This is exactly the force that the prop will exert when you turn the motor. The sharper the turn and more force the motor exerts (faster) the more it will try and capsize you. That's why canoes can fly in a straight line, and capsize when you turn them. Canoes aren't that stable, but the real problem is the motor acting like a lever to rotate (capsize) the boat. If you make it a habit to slow down for turns, and only try and rotate the motor (for reverse) at idle speeds.. then your odds of flipping go down a lot.
good luck!
