Can't find Evinrude Fisherman Model Number
saltmarshfarms
Help, I have what must be a 1960's vintage Evinrude Fisherman 2 cylinder. I don't know the Hp & I can't find the model numbers. Can someone tell me where to look. the only numbers on it are on stamped various parts like 307215, 204974, 303219. No plate I can find. thanks Tom
F_R
Re: Can't find Evinrude Fisherman Model Number
The model number plate is supposed to be on the transom clamp bracket. There should also be a metal disc about the size of a quarter on the cylinder block with the numbers stamped on it. If both are missing, the motor has been stolen at some time. Both number locations don't just fall off.
samo_ott
I believe the fishermen's were 5.5hp till 1964 and then 6hp after.
saltmarshfarms
Thanks guys, I found this motor at the dump. That might explain the missing plate. I'll look for the disk. It needs just a little TLC to get going. Do either of you know what spark plugs it should take or where I can get the info. Thanks again.:)
saltmarshfarms
emerson
ive just finished restoring my evinrude fisherman mine is a six horse and uses the J6J plugs but i also cant find the model number
