cant find infor in manual
alilley
i have fliped through both my seloc and the manual i down loaded tryingt o find info on (it think it is called)the shift interupt. it is the thing that momtearilly interups the power when you shift gears. i am needing to see how it hooks back up......i took mine apart last august and have sleep and not to mention consumer a few cold beverages since then and for the life of me i cant remember how it goes.:confused:
if some one could please send me a pic of thiers (mine is a 3.0/alpha 1) or let me know what page to find it on thanks
KCKracker
Re: cant find infor in manual
click the main forum tab that says adults only, its in the list i think
Don S
It would sure help to know what your engines serial number is, especially if you want the right manual.
Things do change from year to year.
Pete104
Sure, it's OK. We'll be right there!
But, what do you want? A picture of where it goes? How it's connected?:eek::facepalm:
alilley
ok lets see if this helps....serial number off the valkve cover looked like 00348658. i took this pic of what i am working on as well i hope it helps. the 2 main questions i have are how is it supos to connect together? what about the wiring how does that hook up? i am pretty sure that i have it sitting in the right spot and again many thanks
Don S
a = Remote control shift cable attaching points
b = Drive unit shift cable attaching points.
c = Exhaust Manifold
attachment.php
