cant find out the year of 90hp yamaha
phish4fun
the boat is a 88 . cant find any tags on the motor to identify it. the two plates on the bracket are not there. is there a hidden spot on the engine to help me identify it ?
it appears i am looking for a number starting with 90 and maybe 4 letters after it ?
boscoe99
The motor would have left Yamaha with a round decal on the block. Usually in the vicinity of the starter motor. Has some numbers on it. What are they?
Look at the CDI assembly. What numbers/letters are on it?
phish4fun
on right side i found yesterday yamaha cu7383 4907
and 68803 y-2.
i will check the left side tonight.
thanks
robert graham
Check the starboard( right) side of motor bracket….right near the transom for a date of manufacture plate….
boscoe99
Either find the round decal or get the numbers and letters from the CDI assembly or the carburetors.
phish4fun
no sticker or bracket label.
the only other numbers we find is y-3 688h 04. it appears the letter y designates year 2000 in a full part number like c90ty as both sides of the motor have either y-2 or y-3. will be checking the carb numbers today.
boscoe99
Where are you seeing the y-3 688h 04?
The y if not on the PID label on the does not mean the year 2000.
boscoe99
The only markings that count at this point in time are whatever is found on the CDI assembly and the carburetors.
QBhoy
Over here at least…the year can be told by the letter that’s down the bottom right corner of the serial tag plate. Letter on its own bottom right.
boscoe99
Are you talking about the letter P in the illustration below.
QBhoy
why would anyone know where you are calling here?
Why are you bothering to reply with such a silly and rude comment ?
There are at least two charts that tell us the year of these, going by the number in bottom right. It depends on where you live (or where the engine was supplied) .as to what chert to use.
  • Like
Reactions: KJM
boscoe99
Do you have a link to those charts please?
boscoe99
For Yamaha motors distributed by Yamaha USA, the letter in the lower right hand corner is irrelevant. The letter P means nothing to a user.
The fourth letter in the USA model code denotes the model year. For example, using the F225TXRC above, the letter C means that it is a 2004 model year motor. An F225TXRD would be a 2005 model year motor.
Yamaha USA stopped using model years after 2005. There were F225TXR's issued in 2006 thru 2010. All using the same model identity.
99yam40
mainly to find out where his here is.
where is he and his motor located , and where his motor was produced for. makes a difference around the world
