Can't find the model of my carburetor for a rebuild kit.
TampaBoater
Hi folks.
I have a 1984 chris craft scorpion 215 with a GM mercruiser 305 5.0L. The motor was taken from another boat and all I have is the motor serial number. The carb is a 2 barrel. The only number I could find on it was a no go at the auto parts store cross check. Any help appreciated. The motor is probably between 1985-1989....
If pictures hel I will post some later.
Thanks,
Les.
TampaBoater
Re: Can't find the model of my carburetor for a rebuild kit.
After much research on the web, I figured out it was actually a 1996-97 Mercarb 2 barrel, at least by the resemblance of the 2 carbs.
Anyone know about the rebuild kit?
Ayuh,.... The Mercruiser parts link above yer post oughta bring ya to the kit ya need,....
TampaBoater
I counldn't find the rebuild kit for the Rochester 2ge mercarb.
thumpar
Rochester and Mercarb are different. How many mixture screws do you have?
Fun Times
Hi there, If you could you post the engine serial number and a photo of the carb, it may help confirm an ID to help find the correct rebuild kit part number.
mr 88
Take the whole Carb into a NAPA store and let them cross reference it.They have marine catalogs etc usually right at the counter.
