I have a 1979 50 HP Blue Band 4 cylinder (Ser. # 5445498) with the lower unit dropped for an impellar change and just recently put back on. I can only vouch for the motor running on a stand, never had it on my boat.
I put both the shift and throttle cables on properly and can get it to shift from neutral to reverse, back to neutral, then into forward and back again as many times as I'd like. I can hear it engage into all gears and feel it as well. When it is in forward, the prop spins in both directions freely while clicking, clicking several times during each rotation. It won't engage into gear though, there is no resistance.
In neutral position, the prop spins freely in both directions. In reverse the prop turns in both directions. There is a lot of resistance while it works against compression and turns the flywheel. I'm not sure if this is normal in reverse, but I know the spinning freely with clicking in forward is not. Can someone tell be where to begin. Is it just a problem with how I reassembled the unit, splines not in synch or something. I'm just shooting in the dark. Searched the forum but did not get a lot of help. Maybe I missed something.
Thanks a lot for helping.
