Hey everyone. Here's what I have. 91 mercruiser alpha 1. I had the stern drive (upper and lower) off for the winter to replace the impeller and housing. It was leaking so I did that easy fix. I than pressure tested it and all is good. Here is my problem, without stern drive on, the shifter goes in reverse and forward with no problem. I can also shift upper and lower unit by hand with no problem. When I install stern drive on boat than shifter goes in forward but can't get it in reverse. I even took sterndrive back off thinking cable was jammed in there some how. Everything was good there. Also made sure the 2 shifter rods were together right and was all good. Any ideas? I am just clueless here and don't know what to check next.
