I have a 1986 225 Evinrude 225 hp M: E225TXCD S: B1146525
I have been using it all season (3 X a week) since May. Always runs perfect!
Well reverse stopped working, the shift assembly had a lot of play in it, so I could not get enough adjustment to get all 3 gears, so I had it welded and all is well now.
So after that I take it to the water and can't get more then 2500??
I have took all wires off and all compression is mid to high 90's, there is good spark in all wires. while running removed a wire to see if one side is not running all is fine there.
I am getting full throw on the throttle cable, the timing advance is moving all the way to the stop at WOT and the butter fly linkage is also moving to full when WOT.
Fuel delivery is also working fine, ball hard, does not collapse, filters are new, gas is new.
What am I missing??
I have another issue also unrelated and will ask about that after or if I get this fixed!
Thanks guy's!!
What am I missing??
Thanks guy's!!
