chris16371
- Joined
- May 19, 2017
- 156
1973 Merc 500. Started up motor today to check a couple things and the impeller stopped pumping water. I already had one on hand and replaced it but now can't get the lower unit back on. Water tube is positioned correctly and so is shift shaft. The shift shaft coupler was kinda looking bad and I had an extra so I swapped it out but everything is lined up correctly in forward gear.
