Cant Get My Tach To Work
mav6759
I was wondering if someone could give me a had with my tach gauge..I have tried about 6 Different gauges with the same result. I just can get the stupid thing to work...I have to be missing something...When I turn the key the gauge jumps up a little...When I start the motor nothing.. Because I see the gauge move, that tells me I am receiving a signal from somewhere, but the dog on thing just won't work..I even pulled a gauge from a friends boat that we knew worked nothing,,,I played with the pole switch on the back nothing, I traced the purple wire back to the motor it its connected. I believe I have a ground, because the gauge light works...I know i'm receiving some sort of signal because the gauge does more with the switch.....What am I missing...
GA_Boater
It might help if we knew what the h**l motor all these busted tachs are connected to.
sam am I
The circuity internal to the tach, when initially being powered inherently can and will cause the tach's needle to jump some, and course, can vary between tach's and manu's
Since you've checked power and ground(and the needle jumps, usually just mean powers' good and just switched on!), tells you no signal present at tach.
No!! See above...
The signal....
Alumarine
Is it a 4 stroke or 2 stroke motor?
Are you trying 4 stroke or 2 stroke tachs?
mav6759
The motor is a 2 stroke, I'm using a 2 stroke tech...so I'm missing the signal from the gray wire. From what I understand the signal is produced by the rectifier...so I'm guessing I may have a bad rectifier....
The Force power
The signal IS produced by the Stator! however a faulty Rectifier can cause issues.
Does the Rectifier produce voltage with engine running & how much??
Disconnect/bypass the Rectifier & see if the Tach. starts working
sam am I
I believe (I haven't looked it up...I'm being lazy) 2005 90hp Mercury runs a solid state rec/reg module, so yes, most likely a bad tach output on the the rec/reg (common) or a break in the gray wire somewhere between the rec/reg and the tach (sometimes happens)
True, well sorta......."Conditioned" by the rec/reg is more like it, as force says above, its originates from the stator's AC pulses.
Yes but only the tach output (gray wire) is bad sometimes, the rec/reg can still be working enough to charge your batt (should be somewhere around 14V when up at 1500RPM with full'ish charge)
