Supposed to be able to remove the flywheel cover to access the flywheel for emergency rope starts & etc. A small label on the cover says "unplug fuel filter assembly from rubber socket." & "remove three bolts". Problem is I haven't been able to unplug the filter assembly. Apparently it's some kind of a ball & socket type set-up that I just haven't found the secret to and I'm concerned that I could damage something if I keep at it.
Is there anyone who has been through this situation and has discovered the "secret" to removing the fuel filter assembly??
