Ok ... so my Force 125 began stalling at low idle. I read all the posts regarding the carb adjustments and noted that some of you found that the stator may also be the problem. I decided to order a stator and change it now BEFORE lauching for the season. <br /><br />So here I am with a new CDI stator and I can't get the $@#& flywheel to BUDGE!
<br /><br />The nut came off fine. I've got a harmonic puller cranked down to the max, plenty of WD40 in there and no matter how much I hammer it (...easy does it.) - it wont pop off.<br /><br />Someone suggested dry-ice...any suggestions??<br /><br />Joe
