1974 Mercury 850, 85hp. Two years ago I was having problems with the engine staying running even at full thottle. You had to keep priming it or it would die. I took it in last year and spent over a $1000.00 for the carbs to be rebuilt, a new fuel filter and fuel pump, I also had reverse that was out so I swapped a lower unit with a '76 Merc 115hp that was the same shaft lenth and bolted right up. I was told that gears in a 115hp lower unit are so close to the same that it wouldn't make a differance. So last year out in the water it was falling on its face when I first got it out there and I called the shop that just fixed it and they told me to turn out the idle mixture screws until it doesn't do that. Well I got it running fairly well until I had two people or more with me then I noticed that it would not plain off. The RPMs wouldn't go much over 2800 and we would only go 5-10 mph. I kept thinking that it was fuel related so I kept playing with the carbs and found no differance turning the IMS in or out. My prop pitch it 15 and I've never had a problem like this before. I used to pull 2 skiers out no problem. The plugs had some carbon on them and I have some new ones to put in but the old ones didn't look that bad. I do have a cracked bowl cover plate on top carb but I have been told that it wouldn't effect due to being above the float level. I always run 50:1 mix with fresh high octane fuel. Never have had a problem like this and I am stumped. Please any thoughts
