is it really to much weight for 4.3?
Don said:Iis it really to much weight for 4.3?
Obviously, if you can cut back on the weight and it's ok then there is your problem.
If all 6 are adults and on the back of the boat, then you may never get it to plane.
What is your wide open throttle rpm with a normal load and then when you have a full load? It may be possible to change props with 6 on board so it will work better.
milkyway said:I have the 23 ft. maxum cuddy that is rated 1500 lbs. or 11 people.
tommays said:I never really did find out a good use for the 21 prop
Tommays
Wide open with six held 3000rpm thats it
Don said:Wide open with six held 3000rpm thats it
That is only part of the information needed to help you.
What is your WOT with a normal load? And what is a normal load? Are you using the drive trim properly? With a heavy load, you need to start off all the way down and come up with the drive as needed to help plane the boat. You can't just put it in one place on the gauge and expect it to work the same for all situations.
tommays said:Like i said before the prop may be correct when the boat is EMPTY
What WOT RPM do you reach with a light load ?
To proform correctly with a FULL load you most likey need a smaller propwhen you add 1000 + POUNDS of stuff on the boat
Im waiting for my brother to call back with pitch of prop
he might have the marina look at it when its up there i think were turning about 5000 with three people only 3000 with 6 people
