The flywheel nut on my force outboard is completely locked up. When I tap on it with my visegrips and hammer (poor man's impact) the taper moves as well which I'm assuming means the woodruff key is broken also. Do you have any suggestions on how to remove this? Will heating up the nut with a torch work? Is there a proper procedure for this? Thank you for any help or suggestions you can give me!
