shindig888
- Joined
- Aug 19, 2004
- 54
Hi guys, dustin cobb webs off the old 1991 50hp force and need to resolve water in the gear case problem from last season.., I loosened the two nuts (one near water pump, and the one near the gear) and can only get the lower case to split at the rear and not at the front! what am i missing? I don't want to bust anything. I hammered on the "stud" but the case seam wont split at front..? any advice? the shift rod is still in place and bearing cap is off. so far the seals seem pretty good. the output (prop) shaft does have a groove from the seal. not too bad though. Id like to inspect the gasket btween the mid and gearcase and see if thats where the leak is. help would be great!
