I need to remove my 4.3 mercruuser V6 engine to replace the flywheel ring gear. I am unable to select forward gear in order to remove the sterndrive. I understand this is a must due to the shift selector shafts having to be in the correct position to decouple. I have disconnected the shift cable from the assist mechanism and the cable seems to have seized. On further inspection the shift cable bellows is split and I suspect there has been water getting in which has either seized the cable or the shift shaft mechanism or both.
Any advice on how to select forward gear? I don't want to remove the sterndrive in neutral as this could cause damage to the shift selectors.
It feels like chicken and the egg scenario!! I need to remove the sterndrive to change/ inspect the cable and shift mechanism but can't because the cable or shift mechanism can't select the forward gear!!
