I bought an older boat with a 1984 25hp long shaft Evinrude that has not been maintained. I have loosened all the bolts and separated the shift rod. My first question is, do I want to separate it above or below the extension section. It appears that the main bolt is frozen. I've been dribbling PB Blaster on the bolt end for weeks and it does seem to ooze in, but still no movement. I've tried smacking it hard with a large rubber mallet. Nothing. I have a very slight gap (razor blade) except where the main bolt goes through on the rear. One guy suggested that I need to heat it up real hot with acetylene, which I don't have. I only have the small propane can torch. Any ideas? (the black band is a bungy cord)
Thank you
Ken
