I can't shift into neutral. Merc 3.0 LX with alpha 1 drive.
When i try to shift out of gear, there's a 1-2 sec delay before it will go into neutral.
I tried to test the shift interrpter switch and the purple wire was loose ...barely hanging on...it came off as i tried to do a reading with a multimeter. I soldered it back on. Anyway if I do the reading test as per the manual seems like it's an open circuit. If I attach the + lead from the multimeter to the white/green wire from the block and put the - lead from the multimeter to the purple wire from the switch I still get an open circuit until I move the roller approx. 3/16 - 1/4 inch away from the groove, then I get a zero. Is this what is causing the 1-2 second delay before it goes back in to neutral.
