Had new impeller put on by merc mechanic - took the boat out reverse worked fine then later on the same trip the socket broke on the end of the linkage and I had no reverse or neutral. I took it back to the same mechanic and he removed the lower unit and starter and fixed it (or so I thought). Took it out again - reverse worked at first but later in the day the same thing happened, the same socket broke again and no forward or reverse. This happened 2 more times. Any ideas why this is happening? All the posts I read on here with similar issues don't have the reverse and neutral work at all until everything is hooked up correctly. I know this has something to do with the reverse lock hook, its like its getting stuck. This is driving me crazy because i've taken it to the same guy 4 times and its not fixed. I'm afraid to take it somewhere else as they will charge me more and still not have it fixed.
2005 25hp 2 stroke merc
Any ideas? This never happened until I had the water pump replaced.
Thanks
Thanks
