CaptainKickback
- Joined
- Jul 23, 2011
- 1,060
I am restoring a 1981 Sea Ray Sedan Bridge (see my thread if you need the details of the project) and have a question about the joint between the cap and the hull. Being a 30 year old boat, a lot of the lip of the cap that overhangs the hull is not in good shape. Cracks, jagged edges, screw holes enlarged, etc. I don?t plan on ever pulling the cap, so I am thinking about sealing the entire joint from the inside by peanut buttering the inside of the joint and then putting a layer of CSM or two over it. Then I?ll back it with a wood strip for the new rub rail.
Does this present any problem? Does the joint need to flex, and if so, how much? Would just a little fiberglass be too weak to do anything much?
Thanks for the help
Thanks for the help
