dezmond
- Joined
- Jul 21, 2010
- 760
Hey Everyone. Been a loooooong summer so far... I was hoping that I would get my boat in the water this year after re doing the dash for my new gauges but decided I would look over it really good to see how everything else is. Decided that I should do a total REHAB on it. It would always have water in it and took forever to get it all out (I thought) after pulling the drain plug. Soooooooo I decided it is time to pull the deck and see what I got underneath. Yes I know it is a old Bayliner Capri 1750 Bowrider and yes, the factory did a poor job building them, etc. etc. etc. I picked this up for almost nothing with a Ford 2.3 a couple years back. Liked the design of the hull. It fits our family of 4 with no problems at all. I swapped the old Ford for my Mercruiser 120 and outdrive. The motor runs great. We did a bunch of work to it so I am not concerned with it at all.
My plan is the following....
Remove all the carpet
Remove floor, stringers, etc. and install all new
Check Transom (probably replace)
Pull Engine, clean and paint
Clean all outside of hull, sand and paint
Install new wiring where needed.
Install new custom console and dash
New upholstery everywhere
Fab new interior side panels and seats
New stereo system
Layout for more of a fishing boat (maybe integrated livewell somewhere)
More fun projects as time allows
I have all the electronics already so no worries there. Since it is August now, I have around 9 months to work on this project.. I figure if I budget approx. $500.00 / month for supplies I should be ok.
Where can you find a solid boat for $4500.00 nowadays? You can't. That is why I have decided to go this route.
I have an attached single car garage and the boat and trailer fit in perfectly so I will be able to have at her all Winter. I have a couple space heaters that will keep it warm when needed.
Going to use Eeeeeeeepoxy for this project. 1. to keep the smell down and 2. I like it better than Poly.
I made Static and model 1/2 size planes as well as Spinners for Home built planes at my previous job so I have some experience when it comes to shaping, laying glass etc.
I will be sure to take lot's of pics and maybe some videos along the way and post as much as I can. If there is anything I am missing, please let me know. And any advice I can offer I will for sure!!!
One more thing.... I want to remove the old console that is attached to the cap. I want to leave the cap on as I am pretty confident that I can get everything done with it in place and then I know I won't distort the hull as well. I was going to leave the boat on the trailer for this restore. Can I cut the console off??? Both driver and passenger sides will be re designed anyways. I just don't want to compromise the integrity of the hull if I take these off.
Thanks in advance
This is going to be a fun ride!!!!!!!!
New stereo system
Thanks in advance
