Capt Tolley on rivets?
snapshotmd
Has anyone ever used this stuff? http://www.captaintolley.com/
I was over at West Marine looking for Gluvit but found Capt Tolley's instead. I'm using it to seal a loose rivet which is holding the keel guard to my aluminum boat.
Am I wasting my time with the Capt?
Bob_VT
Re: Capt Tolley on rivets?
I read the spec sheet and it will not perform like gluvit..... it will not fill large cracks..... it must be applied less tham 1 mm thick...... not anything I would try or spend money on. It is obvious it needs air to dry while gluvit is a chemical reaction of epoxy.
Want a cheaper sealant for a rivet .... use 3m 5200 which is thin enough to creep
