Hi all,
I need some advice about my exhaust. I bought a 2002 Chaparral 265 SSI last year. I was having problems with overheating of the exhaust due to the common problem of wear in the seawater pump. I know that I overheated the exhaust system on at least a few occasions. I just put in a new Hardin pump to correct the priming issue but I am concerned with the diverters and rubber connections surrounding the Corsa switchable exhaust. I have evidence that the exhaust got very hot in the form of partially melted wire looms in close proximity to the risers and diverter assembly.
What I don't know is whether or not I need to rebuild the diverters and replace the rubber connections to the riser, "Y" pipe, and side exhaust elbow. I do get some drips from around the rubber and can't seem to tighten the clamps enough to stop them but they are minor. If I do need to perform these repairs, do I need gaskets for the riser? What is the easiest procedure to R and R the parts?
Thanks in advance
2002 Chaparral 265 SSI 496 MAG Bravo III with closed cooling and Corsa Captain's call exhaust.
Thanks in advance
