Re: Captivation Plate 3" lower than Transom, how big of an issue
Yes and no. The primary reason for the odd leg length was that transom sizes were not yet standardized (15" regular-20" long), as a result OMC see to have sort of "split the difference" at 18". While it is true that they do have a water uptake above the anti-plate, it really only comes into play at low speeds/idle when the motor is sitting relatively low in the water. The pumps themselves are relatively weak and are not self priming, hence the need to use a test tank. However, once the boat is at speed and on plane water is forced into the screened opening directly in front of the prop then onto the water pump and up to the powerhead. At this point, the water uptake found above the anti-vent plate can/should break the surface of the water. This will reduce drag while still allowing plenty of water to be taken up by the motor. As the boat slows down again, it will again sit lower in the water and resubmerge the uptakes above the anti-vent plate. Not to worry, jackplates/transom risers have been used on these old motors for years. The old timey racers would even use shims as little as 1/4" to dial in just that right height. Obviously, you don't want to set the motor up too high and it will take some experimentation to get it dialed, but it's well worth the effort. Your boat will steer much more easily, get on plan faster and have a shallower draft. I also stand up using a tiller extension most of the time while underway, and having the motor a few inches higher reduces the angle of the tiller a bit which makes the throttle a bit more responsive too. If you want a fancy-shmancy jackplate, check out bobsmachineshop.com.
