Re: Car guru's
When your about to take it out mark where the rotor is pointing ,then where the dist enters block mark block and dist housing take hold down bolt out pull dist,then as Ken says little waver ring clip on top of pick-up coil before you put new one in lube dist under pickup and shaft[clean motor oil] Put dist in with rotor mark off a bit as it will turn a bit as the gear contacts cam gear and slides in You might have to pull out turn rotor again to achevie the line up mark for the rotor Just do it till it lines up right might take a couple of trys Then line up bottom housing and block mark , tighten hold down Check timming should be very close if both marks are lined up
