Carb Adjust help
BaylinerCapri1331
ok I know how to adjust a single carb what do I have to do to adjust the linked carbs on an outboard motor?
Frank Acampora
Re: Carb Adjust help
see the answer in the link and synch seloc pro post.
Start with 1 1/4 turns out on the mixture screws. Adjust each about 1/8 turn or less at a time and keep them equal. Do not adjust mixture screw too lean! less than 3/4 turns out from lightly seated will cause detonation and melted pistons at or near full throttle.
