acdc96
- Joined
- Apr 23, 2013
- 412
My 1987 mercruiser 260HP V8 has carb problems. I just started the engine today since August/September of last year and it runs like crap. I just cleaned all the water hoses, thermostat housing, and water circulating pump. And put it all back together.
The carb has not been rebuilt in a while (2-3 years I think? Maybe more). But the choke is staying shut for some reason. The device that opens and shuts the choke moves as it should. The linkage is all their for the choke. I can open the choke manually by hand but as soon as I let go it springs shut.
I was running it at half throttle to keep it running. I had zip tied the choke so it would be somewhat open. It sounded healthy but acted like it was starving of fuel. The jets are clean. When I advance the throttle I see the jets squirt out gasoline.
Also, when it was running I saw little puffs of blue smoke come out of the flame arrestor. The engine would lag every time it would do that.
I just drained the block of water. Yes I took the block and manifold plugs out And un hooked the water pump and power steering cooler hoses.
What is wrong with the carb/choke?
I believe their is a spring missing. I don't know that why I'm asking.
