jmznshana
- Joined
- May 16, 2012
- 35
I apologize for the length but want to be detailed. The boat 95 monterey montura bowrider , here's what it's doing and what I've done so far. The motor- Merc 5.7 w/ thunderbolt ign. Motor is new (crate motor) to boat approx 5 yrs ago w/ maybe 100 hrs on it. Last season it developed a carb backfire that occurred when I dumped throttle for hole shot and occasionally while cruising at around 75% throttle and any time I added throttle from that it would pop. Didn't get a chance to run boat this year but about 3 times. The first time out back in March it ran fine for a short 20 cruise, it sat for a few hours and on the way back it was backfiring pretty bad at lower rpms I couldn't get it over 2000 w/o it backfiring repeatedly... After that trip i did a lot of reading here and believed the problem to be a lean fuel issue related to the accelerator pump on the quadrajet. I replaced the carb with a new completely rebuilt carb, new fuel/water separator, checked the plugs, cap and rotor. All looked good w/ no issues. Got it out after that and it seemed to run much better. It did backfire a few times still, although nothing like it was and only when I rapidly dumped the throttle from standstill.... WOT had no issues. Took it back out this past weekend and had issues again but an added one this time. While no wake cruising at maybe 1500 rpm it was backfiring and also could a sluggish hesitation. Could not hear the motor missing or changing its tone but could feel it in the motion of the boat if that makes sense.... I started the day putting in 2 new batteries as they were dead. Noticed for first time that day also the volt meter on dash had a lot of movement... When sitting idle it showed 12-13 volts. As soon as I put in gear and had a load on the motor the needle dropped to 9 +\- volts and this is when the backfiring started.. Also at about 75% throttle it felt like it was not getting full power, like I had to use more throttle than usual to keep the speed I was running 30-35. Water was flat so no wave or wake issues. I took the alternator in and it tested good today.... I'm out of ideas at this point.... Please help Thank you
