carb cleaner
sirjin
Would you use a carb cleaner for a 1994 30HP Evinrude and would any brand of cleaner work?
D
DJ
Guest
Re: carb cleaner
No, carb. cleaner contains no lubricant and will wash the oil out of the bearings in the crankcase.<br /><br />If you have carb. trouble, remove the carbs. to clean them.. You can use carb. cleaner to clean them in once they are off.
sirjin
Re: carb cleaner
Thanks for the reply.<br /><br />I was kind of curious about carb cleaners and if they would work for outboards. The last thing I want to do is do more damage than good.
