Carb Cleaning Question on 1977 15hp
Chadgro
I just baught a carb repair kit. I replaced the float, needle and seat. Removed the large aluminum cap acleaned the 3 holes out. removed the idle mixture needle and cleened that area. It seems to start and idle much better now (maybe perfectly). However, the kit came with 2 more aluminum caps ( much smaller) what is under those? It seems pretty tricky to remove them. I am trying to maximize my, full throttle, power of course. Do I need to remove these small caps or replace any other carb parts?
I thank you for any tips or advice.
iwombat
Re: Carb Cleaning Question on 1977 15hp
If it runs perfectly, you can forget you ever saw them. Those side passages don't pass much fuel and rarely ever need cleaning.
tashasdaddy
did you remove the high speed jet and clean it?
Chadgro
The high speed jet was part of what I was curiouse about. I dont know exactly
where it is. What does it take to clean/replace it?
Thanks
