carb. electric choke.
Rich Novak
1972 225 sterndrive electric shift. Omc
Changing the carb. To the correct marine type.
I want to go to a electronic choke, is there a place to hook the hot wire to in the engine compartment rather than running the wire to the ignition switch.
Thanks, Rich
bruceb58
You have a ballast resistor that feeds your coil. Hook the wire to the input of the ballast resistor.
bruceb58
You have a ballast resistor that feeds the + side of the coil. You don't want to use that side of the resistor. You want to use the other side of it.
Rich Novak
Thsnks, the carb s/b here Fri.
Hopefully it will solve my problem then I can enjoy cruising.
Rich
Silvertip
What is the problem? And just because you have the electric choke it will not solve a problem unless it is properly adjusted. Do that adjustment on a stone cold engine, not after it has warmed up.
