Re: Carb Float Adjustment
Hey all thanks for all the advice. I checked the float adjustment again still looks good, float drop within specs, I did check the seat valve again by removing it then blowing compressed air through it I checked the needle with a magnifying glass the tip is good which I suspected it to be since I replaced the needle and seat when I rebuilt the carb. I did notice that the seat valve was not very tight when I removed it, when I reinstalled it I tightened it down more, put the carb back together and with the carb upside down so the needle would be seated I tried blowing through the fuel inlet, the needle is seated as it should be no air escaping, I turned the carb up right so the float would drop then back over and tried blowing through the fuel inlet, again no air escaping. I will install the carb and start it up to see what happens. I am hoping that tightening the seat valve more did the trick. By the way I did not blow compressed air through the fuel inlet just the air out of my lungs.
