fishn_n_tx
- Joined
- Mar 22, 2004
- 26
1971 50 hp <br /><br />Another week, another problem. Motor was running fine and started to bog down. Hard to start, used to start with the bump of the key, and dies when idled down. Under the air intake it is fuel washed and oily. I took off the air cover and the top carb has fuel standing in the carb. When choked it gushes fuel out, motor turns a little slower on the starter, like it got the plug wet. I took the carb off, checked the bowl and jets, the one that can be seen thru the drain screw hole, and all is clean. Re-assmbled and the same flooding. <br /><br /> Do needle and seats get worn to the point of not working? <br /><br /> I plan on doing carb kits in both carbs this weekend.<br /><br /> Other questions while were at it. What is the function of the power pack? On this motor I thought it was just a junction block till I seen one looking for carb kits.<br /><br />Is there an easy way to tell if the motor is putting out as charge to the battery?<br /><br /> Thanks for any info, Gary.
