I saw what appeared to be a well-maintained 2003 Evinrude 9.8 HP 4 stroke today (pull start) at my local marina. The marina told me that the history of the engine was that they had fouling problems with it. It was used as a kicker and when it would run at low speeds for long periods, the carb would foul. She said they drilled it out, and even changed the complete carb and could not mitigate the problem when used in a low-idle capacity for long periods (why a kicker would be "low idling" I don't know).
Nonetheless, she said if I were to buy it and use it as a fishing motor on my 14' boat she sell it in good conscience, but should I want to use it as a kicker on my larger boat, she would not recommend selling it. She also said that it was actually a Johnson 4-stroke, painted and branded to look like an Evinrude to match the original owners main engine. Also weird, but I had a 55 HP 4 stroke Johnson that I loved so that doesn't bother me, albeit it may be relevant to diagnosing a known problem with the carburetor problem so I thought I'd mention it. I need to get a closer look at it to confirm that.
The obvious thing to look at (to me) would be problems with ethanol fuel that might be remedied with higher octane fuel and some Sea Foam. But that seems so obvious that I can't imagine the mechanics didn't consider that. I appreciate the marina's honesty and they do an excellent job of maintenance on my 90 HP e-Tec, so I know their mechanics aren't incompetent.
Anyone heard of such a thing on a newer motor or have similar experiences?
