carb gas
agib08
so i finally got my motor to start. well i was watching the parts making sure everything looked good. except that my carb is shooting small drops of gas out of the top carb. is this normal or whats going on?
thanks in advance
JB
Re: carb gas
What outboard is that, agib??
Silvertip
Re: carb gas
If it is shooting gas out the vent the floats are stuck, misadjusted, bad inlet needle and/or seat, or there is debris in the carbs that is preventing the needle and seat from closing off the flow of fuel.
Big Pete
Re: carb gas
thanks in advance
Is it like mine on this video ? Shooting from the same place as this ? http://www.youtube.com/watch?v=ZWANWTnjpNA
mine is 80hp Mercury 3 cylinder ...
sschefer
Re: carb gas
Now that's a needle valve not closing on a WME carb if I ever saw one. Several possible causes. Usually a piece of gunk under the needle but could be a saturated float, worn needle or worse case scenario, a bad seat.. Seats are not replaceable so you have to replace the carb if that's the cause.. By the way, it's rare.
Big Pete
Re: carb gas
Hi thats why i asked about the carb cleaning and now the pile of junk is out the water i am gonna tackle them :)
Whats the saturated float all about ? havent heard that before
sschefer
Re: carb gas
The floats can be a solid / coated foam or hollow plastic. Sometimes the coating breaks down and they become saturated and don't float. The plastic ones have been known to leak when subjected to ethanol fuels (doubt you have the problem in Mallorca).
