Hey guys, I was fishing the other day a few hours after putting threadlocker 290 self wicking formula around the carb gasket, where the bowl meets the upper carb body. It is suppose to seal any small air leaks that occur from the actual carb. I did it preventatively, but an hour into fishing it was coughing and sneezing bad at low idle. Im thinking maybe it seeped into the carb and some is stuck somewhere. Ran fine midrange to full. Today I replaced plugs, gas, and even swapped a spare powerpack, finally I used a spray bottle of premix while it was lean sneezing from exhaust which helped it purr like a kitten. So, my diagnosis is now a faulty low speed carb problem. My idle needle never moved, I tryed to adjust it anyway in small turns, with time in between, to no prevail... the sputtering didn't change.
So I took my carb off, bowl is clean as well as high speed jet. My problem lies in the fact I know nothing about cleaning the low speed portion of a carb. Its an 86 johnson 25 tecdc, I was hoping you guys could point out the most likely spot for a blockage or whatever is causing my coughing problem. I don't really know how to adjust the needle so that it seats either. I have heard of the upside down blow in/no air out trick, but thats just to check your work once everythings together. Any help is greatly appreciated, I'm not confident after reading the low profile carb readings. Heres a pic of my carb.
