FreightTrain
- Joined
- Nov 30, 2005
- 4
In my first post I posted how my 55hp yamaha wasnt able to run at wot and would stumble and act like something was wrong. Well today I was able to mess with the boat some more and noticed that on the top carb fuel was leaking either from were the carb mounts to the engine or from the bottom bowl screw. It was really hard to tell from which it was leaking but there was a decent amount of fuel in the bottom of the case and you could see a slow drip off the fuel bowl screw.<br /><br />My question is do you think this is causing my stumbling problem and would a having a shop clean the carbs fix this problem or should I just have em rebuilt at the same time. I just bought this boat so the maintance history is any body guess although the previous owner claimed he had the carbs rebuilt 2 yrs ago. While I have the boat in the shop would it be wise to go ahead and have to fuel pump redone and the water pump also.
