carb help
bstagner
i have a 1969 55hp johnson haveing carb problems i have a set of fixed carbs off a 70 johnson the i think will bolt up can any one tell me if this will work thanks
The Marine Doctor
Re: carb help
If the venturi measures the same size...they "MIGHT" work. You will have to do some jetting though.<br /><br />TMD
Dhadley
Re: carb help
They will bolt up although you may have to do a little jetting. The newer ones don't have choke plates so you could upgrade to the injection primer.<br /><br />Good luck!
