Hi all I wonder if anyone can help me with this:-<br />Mercury Bluband 50 HP 2 Stroke 4 Cylinder 2 carb.<br />I am in the middle of servicing the carbs, this is the first time I have carried this out on any engine. I am following the Clymer Mercury Outboard Shop Manual 45 - 25 HP 1972 - 1989 (B726).<br />The carbs appear to be those shown on page 134 and 135 which are the Integrel Fuel Pump Carburetor (Except 45 and 50 (4-Cyl) HP Models). Actually marked on the carbs is WMA 3-3 for the bottom carb and WMA 3 - 1 for the top carb. Both carbs also have the date 8/84 stamped on them.<br />I have two questions the first being:-<br />I am following the manual and have managed to get everything completed up to part 6 stage B (Fig 13). At this stage I have located and removed the idle restrictor tube plug screw (A. figure13) and now need to unscrew the idle restrictor tube from inside the main discharge nozzle. I presume this is inside where the screw (Part A) comes from. I can't work out how to get it out. I can see a very small brass coloured tube inside but it has no marks or cuts in it to allow you to unscrew it with a screwdriver. Has any one worked on this carb and if so am I missing something. Or is it that I have a carb wher the tube doesn't come out.<br />Once I have got the tube out then the next part is to remove the fixed high speed jet. I don't want to do this in case the tube is fitted in to it and I damage it. Obviuosly I would like to follow the manual so i can clean the carb properly.<br />Any help would be appreciated before March so i can get the engine back together and on the sea.<br />Regards Biggles...
