Re: Carb jet sizes.
Thanks, Ill find the serial # and post it.<br /><br />The main jets are now 64s, but the Idle air bleeds are 70s. This will make the engine Idle very lean if my calculations are correct. Bigger #, = more air meaning leaner. There are no jets in the front of the venturi opening, I know some dont have them but they are threaded.<br /><br />This is a set of carbs Im working over to install this spring. The carbs on the engine are the same carb #, and has 64s for mains, and 54 for Idle air jets. Im going to drop to 48s on the Idle side, and go up to 66s on the mains.<br />Im right at sea level here so things seem a bit lean on both ends.<br /><br />Thanks for the link, very helpfull.
