Carb Kit Replacement 1981 4HP Envrinrude (E4WCIC)
tobyguy
Hi All,
I replaced the Carburetor components as per the Carb Kit out there available on many sites.
However, there were a few components I wasn't certain where they were located to replace or how to remove the old one.
See picture attached (I had 3 pieces left over, A. Nylon washer, B. Rubber something or other and C. Plug Expansion).
A. First, I don't know where the 3rd nylon washer is that I replace (had 1 left over)
The kit came with 3 (I put two where its labelled number 8 on the carb kit picture).
The old pieces there had 2 rubber washers and 1 see-through plastic, so I replaced it with 2 nylon ones and a new see-through plastic washer (not sure if I should have just put in 1 nylon or 2).
I don't know where the other one goes. I see #23 and #24 in the picture, but I it doesn't tell you where they go (nor could I tell where they were in the actual carb when I opened it up)
B. I have no clue where the red rubber thing goes (there's nothing like that I could see when I opened up the carburetor kit.
C. I see where the Plug Expansion is suppose to go (labelled number 5 on the carb layout picture), but I have no idea how to remove the old one (not sure I should replace it to be honest. Looks like its pressure fitted or something. I'm thinking the old one is probably fine)
Would appreciate any assistance on how to complete my carburetor replacement kit.
thanks,
Tobyguy!
