Carb kits/fuel pump kits 1991 force 150hp outboard
huck1545
Hi, Looking for help finding carb kits and fuel pump kits OEM preferred.I been searching using my model/serial number that is labelled on the side of the leg and it reads as MODEL# 1508E91J SERIAL# 024717 I can't seem to find that serial # online.Will there be a part # located on the carbs? If so where would that number be located?Thank you for your input.
Cheers
Shane
jerryjerry05
Just look at the pump, square (new)or in the shape of the number 8(old)
F438747 Diaphragm need 2 for the old style.
857005A1 Kit for the newer style need 2
roscoe
Looks like carb kits are NLA.
Most Individual parts still available from a Merc dealer.
mercruiserparts . com/bam/subassembly/30037/1116/130
jerryjerry05
Usually the carbs don't need kits, just a good cleaning.
The bowl gasket might fall apart when you remove the bowl.
I spray WD or any penetrating oil on the gasket for a day or 3.
This helps the bowl/gasket release without damage.
It also swells the cork(if it's cork) and helps reseal.
Do a good inspection of the needle/seat.
Franz Marine might sell the kit.
Otherwise the individual parts are readily available.
The part # for the kit.
