I have a 1988 85hp motor.Gas leaks from the first carb on top when pumping bulb with the engine down in the running position.New fuel pump and primer bulb.HELP!!!
Hi, Sounds like you may have a sticking float needle ,you may have pumped some crud into carbs at pump service,strip and clean carbs and check float height adjustment . Jim B
